  3. Import Netlist to OrCAD PCB Designer 17.2 gives error but...
  • Views 15007
Import Netlist to OrCAD PCB Designer 17.2 gives error but no description of Error
ajeya
ajeya over 8 years ago
I have a good netlist from OrCAD Capture CIS, that I import using . Import > Netlist > Import Logic Type "Design Entry CIS(Capture), Place Changed Component "Always" > Import Cadence
which yields
#1   ERROR(24) File not found
     Packager files not found
#2   ERROR(102) Run stopped because errors were detected
netrev run on Aug 28 17:59:59 2017
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
  2 errors detected
 No oversight detected
 No warning detected
cpu time      0:00:12
elapsed time  0:00:00
Any hint on what error 24 is ?
Ajeya
  • oldmouldy
    oldmouldy over 8 years ago
    Error 24 is "Packager files not found", if you look earlier in the log file contents, you should seethe "import" directory, that is where the three dat files, pstchip.dat, pstxprt.dat and pstxnet.dat, need to exist. It's quite possible that the netlist failed to be generated from Capture, you would need to check the Capture Session Log for messages about that.
  • oldmouldy
