  3. Allegro 17.2 Component Placement Problem
  • Views 17136
ajeya
ajeya over 8 years ago
I am new to Allegro.
I have a .MNL netlist generated from Capture CIS 17.2. On Import to Allegro 17.2, view log says netin imported successfully.
When I do Place > Component Manually > The list is complete with all the components in my schematics. However, I do not see any graphics in Quickview or any indication of presence of component.
When I check-mark a component and move the mouse over to the Allegro screen, there is no component visible.
In the command line log, it says > Cannot Load Symbol
How do I proceed from here ?
  • Eugene Yeoh
    Eugene Yeoh over 8 years ago
    Did you setup correct path for your footprint?
    Setup>User Preferences>Path> Library>psmpath
    Setup>User Preferences>Path> Library>padpath
    Eugene
  • ajeya
    I get the component from Schematics listed as "Components by refdes"> "Component Name", I can click it and get a tick mark. How do I find the corresponding footprint and link it to the component so imported. I cannot see anything in Quickview. There is no option which says about finding and linking a footprint to this component. I have checked the path, both are showing up. I have also added my old footprint library file folder path, but no use. It does say "Cannot load symbol"
    What can I do next ?
  • oldmouldy
    oldmouldy over 8 years ago
    Check the contents of the netrev.lst for any errors that may have resulted from loading the netlist, quite likely, there will be some "not found", "pad mismatch" and so on that indicate that the netlist failed to import correctly.
  • oldmouldy
    Apologies, I just noticed that you have an MNL netlist, that is the wrong format, but, equally, you would not have any components listed in Place>Components Manually for the wrong format so, "something" about your description of your actions is unclear in trying to resolve the issue.
  • ajeya
    So, .MNL is an unsupported Allegro format for netlist import, though Capture can generate .MNL ? Kindly elaborate
