  3. single layer pcb
  • Subscribers 166
  • Views 14725
single layer pcb
tracemhos
tracemhos over 8 years ago
I'm trying to create a single-layer flex pcb in allegro and cannot seem to delete the second layer from the cross section editor. Am I missing something obvious? (Allegro 17.2)
  • oldmouldy
    oldmouldy over 8 years ago
    That would be correct but you can generate Artwork films for only the layer(s) used and ignore generating any output for Bottom, for example. You could have a Route Keepout on Bottom, for example, to prevent connections, this could be "all over" and not necessarily "just" match the Design Outline.
  • tracemhos
    Thats fine for generating artwork, however I can't generate an accurate cross-section diagram if I can't delete a layer. Is there really no way have only a single layer in the cross section?
  • Avalex Steven
    Avalex Steven over 7 years ago
    I'm having the same issue as this.  Was a solution ever found?
  • tracemhos
    tracemhos over 7 years ago in reply to Avalex Steven
    The only solution I've found is to manually delete the layers in the cross-section diagram. The whole thing seems wonky
