  3. Custom Pad Shape with Multiple Openings in Solder Paste
  • Views 15118
cgabbott
cgabbott over 8 years ago
We are working with more QFN packages, which all have the center pad. On almost all datasheets they recommend the stencil design for the solder paste on this center pad to be an array of multiple openings to make sure that a) not too much solder is applied and b) it is well distributed over the surface of the large pad.
I tried to create a custom pad, but cannot as I am only allowed ONE element in the shape.
Since this type of stencil design is now "common place" how is this being supported inside Allegro ?
e.g. of this from the TI CC2650 datasheet
  • oldmouldy
    oldmouldy over 8 years ago
    Maximum flexibility is to add Package Geometry / SolderPaste Top static shapes to the Pin area in the Symbol Editor, works in "any" version. 17.2 Padstack Editor would allow use of Flash Shapes for Solder Paste, but you need to create the Shapes as a Flash Symbol in PCB Editor and the add them to the Padstack Editor, which is more effort than the "old" way.
  • cgabbott
    Thanks I will put them in the symbol then
