  3. In Allegro 17.2 and previous versions, In the "CONNECTOR...
  • Subscribers 167
  • Views 2970
In Allegro 17.2 and previous versions, In the "CONNECTOR" Library of the OrCAD software, the Pin4 and Pin6 positions of the "CON18A" component symbols are wrong.
Kinzhifeng
Kinzhifeng over 8 years ago
Will this problem be fixed in later releases?
  • Kinzhifeng
    This is a dynamic picture. Please click the picture!
  • steve
    steve over 8 years ago
    Yes it is and I'll report this to Online support but it may be quicker if you edit and resave the part yourself. Remember these are only sample provided libraries so you should check all of them for form, fit and function anyway...
  • Kinzhifeng
    Thank you, but this problem still exists in the latest 17.2-2016-S027 hotfix, which doesn't seem to fix the bug.
  • cesyg
    cesyg over 8 years ago
    This is why I never EVER use vendor-supplied libraries, other than treat them as learning resources.
  • djs42
    djs42 over 8 years ago
    Agreed.
    NEVER use any library parts without thoroughly reviewing and modifying first. From any source - CAD Vendor, Component Vendor, 3rd Party Library Vendor.
