  3. Change the font in an entire design in Capture
  • Views 18484
RBATES15
RBATES15 over 8 years ago
Is there a way to update the font in the entire design all at once? I've already completed the design but the font size is causing issues when importing into Pro/e. I want to increase the font size of all the text.
  • steve
    steve over 8 years ago +1
    Possibly as long as you have used the default setting. Try this. Launch Capture and setup the default values under Options - Design Template. Then create a new project, open your old design and try a copy…
  • steve
    Possibly as long as you have used the default setting. Try this. Launch Capture and setup the default values under Options - Design Template. Then create a new project, open your old design and try a copy / paste from old to new. If you've used the default values it should apply the new default values to the copied pages.
