  3. Mirroring Layers
  • Subscribers 166
  • Views 17008
Mirroring Layers
Sagetech
Sagetech over 7 years ago
Did a board for a customer who now wants to have a mirrored version of the board. It's not a complicated board, just a couple switches and connector,  several layers of copper areas though.
Thought I could export a dxf of each layer, mirror it in autocad and then import it back in and assign the nets to the copper areas. This sort of works, but the copper areas do not import. They are visible in the dxf.
Suggestions?
Tom
  • B Bruekers
    B Bruekers over 7 years ago
    There is (afaik) no easy way in Allegro to mirror a design.
    However, you can buy some extra 'tools' that can mirror things in the design itself, for example www.flowcad.eu/FloWare.htm
  • eDave
    eDave over 7 years ago
    You can export the design as a module (mdd) then import and flip it.
  • Sagetech
    Can not find the  "Create Module" command in PCB Editor (Pro)...........?
    Is this only an Allegro feature?
  • eDave
    Possibly.
  • oldmouldy
    oldmouldy over 7 years ago
    OrCAD PCB Designer Professional and above supports modules through Placement Edit Application mode, Setup>Application Mode>Placement Edit, window components, hover over selection, right-click>Place Replicate Create, modify the Etch selection (if required) and right-click>Done, pick an origin, like 0,0 or Snap a Pick To, then specify a name for the module to save it.
