  3. cannot see ( ok, cance, apply) on quick place window.
  • Views 13651
chadga
chadga over 8 years ago
I am using Orcad pcb professional 16.6 as well as 17.2. when i go to quickplace in 16.6, i am able to see the full window. But when i go to quickplace in 17.2, i am not able to see the "ok", " cancel", and "apply" buttons.
My screen resolution is set to 1366x768. This happens in few of the systems. But in one system when i open quickplace in 17.2 and hover the mouse to bottom of quickplace window, it will scroll the window and the "ok" "cancel" "apply" buttons will be visible. When i hover the mouse in my system, it doesn't scroll down. Is there any settings which has to changed or enabled for scrolling the window. Please help me on this issue.
To be clear, all the screens are set to same resolution. The same issue arises when i open "step package mapping".
I have attached the screenshots of both 16.6 and 17.2 in a single pdf .
PFA.
Thanks and Regards,
Chadga
  • chadga
    Please, can anyone give me a solution for this problem.
  • Kinzhifeng
    Kinzhifeng over 8 years ago
    My notebook computer resolution is 1366x768, I also encountered this problem in 17.2 above, I usually press ESC to exit, make sure that I am directly on the Enter key on the keyboard, I hope the next hoftix can solve the bug...
