  3. better Free Allegro Viewer - Orcad Lite
  • Views 3815
robspcb
robspcb over 8 years ago
Since Engineers need a way to view allegro board files.
 And the Orcad Lite has more functionality , why not use that.
my blog at robspcb.com/blog/
Pcb Designers and Engineers need to be able to view the same database.
 So , those Viewers that don't chew up a license, are a great deal.
The regular Viewer is really limited in functionality , thats where Orcad Lite comes in to serve as a Viewer.
 Of Course there are a couple of install caveats.
One of them, if you already have a license, it would use that up.
 Made a  Batch .bat file as a workaround, that way you can have multiple lite open.
Steps:
- download Orcad lite
- create shortcut on Desktop
- download PCBeditorlite_no_license.bat
- put on Desktop
PDF
  • Dale Peterson
    Dale Peterson over 8 years ago
    Rob,
    I'm surprised that someone hasn't commented on your suggestion yet. So, let me take a crack at it. Using  OrCAD lite is a good option if you are viewing small PCB's. Cadence has placed limits on the number on nets that can be on a given design. If your design exceeds the limit, OrCAD lite will not load your file. I agree with you that the free viewer lacks big time my opinion as well. Cadence needs to produce a viewer that looks, smells and functions just like the real thing. But, has all its manufacturing output routines and file saves disabled. Whats wrong with that! I know some of their competitors have this.
    Cheers
  • steve
    steve over 8 years ago
    That's not true I'm afraid. OrCAD Lite will load ANY design size BUT if you are over the demo limits then any Save, Export functions are disabled
  • Dale Peterson
    Steve,
    I stand corrected. Thanks for the your input.
  • robspcb
    Orcad Lite needs enabled ,
    - printing
    - color view save
    - reports output
    to be a useful as a viewer
  • steve
    steve over 8 years ago in reply to robspcb
    You can print and you can create a color view file but no reports. I'll mention this to Cadence.
