  3. Read Only library problem with OrCAD 17.2.029
  • Views 14860
vavouris
vavouris over 8 years ago
Hi all,
I have a weird problem with Orcad 17.2 that i just installed (with latest hotfix). When i open an old design that i had made with OrCAD 16.6, it says that my library file is used by another user and it has to be opened in readonly mode.
Every time i have to remove the library and re-add it to work with it. And i can guaranty that i am the only user of this library file. No one else uses it and it is not on a shared folder or anything like that.
Is there a way to see who OrCAD thinks is using the file?
Theocharis
