  3. 2 Pads having the same Pin number
  • Subscribers 166
  • Views 14274
Scuud
Scuud over 8 years ago
Hello
I designed a foot print for a connector" The suggested footprint looks like the one below.  This connecteur only have 2 positions, so this means 2 pads are electrically connected.
on my layout on Orcad PCB editor, i designed one as being the electrical pin and the other one being the mechanical one. The idea is that when I connect the line, i can start from one or the other pad, and the software will know the pin is connected. unfortunately, I cannot connect a mechanical pad, and i cannot design a pad with 2 shapes.
how am I supposed to do it?
Thanks a lot
  • redwire
    redwire over 8 years ago
    You need to make sure that any pins that are connected electrically have a pin number.  You will have to adjust your schematic symbol accordingly.
  • S0undman99
    S0undman99 over 8 years ago
    I would look up the PACK_SHORT property.  You can add this in part developer for DE_HDL.  I'm not sure about Orcad.  This allows the packager to know that when it packages the design, that these pins are shorted together.  The other option, which is what I think redwire is suggesting, is to have a total of four schematic pins that then map to the the four physical pins, and then just connect those pins together on the schematic.
