  3. How to link a spiral inductor to its symbol in schemati...
  • Views 14831
How to link a spiral inductor to its symbol in schematic
Leron
Leron over 8 years ago
Dear All,
in my schematic I have an inductor. This inductor does not have a corresponding component for PCB because I want to realize it as a spiral printed on the PCB.
I am wondering how can I create a PCB footprint that is in principle just a piece of metal on the etch/top layer but with two pins in order to have the netlist and the brd to be correlty created.
Any suggestion?
Thanks a lot
Francesco
  • steve
    steve over 8 years ago
    Make a footprint (filename.dra) of the spiral track that simply contains two pins (for the connect points). You can make the pins just a small smd dot pad (say 0.2mm) and make sure it is just a TOP pin with no mask or paste). Place these at the connect points of the spiral winding. When the part is placed you only have to wire to the spiral,
  • Leron
    Leron over 8 years ago in reply to steve
    Hi Steve,
    thanks.
    does this mean that everytime I use the inductor I have to design it on the PCB? I am worried that connecting with spiral etch the pins in the .dra will result into an error since the two pins will result as electrically shorted.
    Francesco
  • steve
    steve over 8 years ago in reply to Leron
    No, design it as a symbol and then once it is in the board the copper will take on the netname of one of the pins and you will see a DRC error. Use the NET_SHORT property on the pins (Edit Properties then select the Pin) which has a value of netname1:netname2, this means you can effectively short the two nets together.
  • steve
  • Leron
    It works.... thanks a lot!!!!!
