  3. Different propagation velocity on each layer
  • Views 14315
Azertyop
Azertyop over 8 years ago
I need to constraint delays in terms of timing (nS) with routing across different materials in a multilayer pcb.
I use materials with 1.43 10 e+008 m/S and 1.66 10 e+008 m/S.
How can i define these different values on each layer?
I can't define constraints in terms of length, because i have to take care of package pins delays and via delays which are timing defined only.
  • steve
    steve over 8 years ago
    I don't think you can set this by layer but you can set this by design. Look at Setup - Constraints - Modes - Electrical, and you can set velocity factors for Pin Delay and Z-Axis delay. You may be able to do a custom worksheet in Constraint Manager but you may need to try this to see if this is what you want.
