  3. Allegro PCB - Command window 'SYNTAX ERROR'
  • Views 3123
entangled
entangled over 8 years ago
Hi
I have some error outputs every time I open Allegro PCB Designer either through a file (double-click) or by a Windows Shortcut.
I attach a small txt file with a dump of this "log".
Is any of these an indication of potential malfunctioning/ problem? Should I just ignore them?
Best Regards,
Andreas
Fullscreen Alllegro_command_window_errors_02122017.txt Download
Loading axlcore.cxt
W- *WARNING* (reader): string terminated by illegal char \320 at line 1 of string "...etSkillPath ". C:/Users/U"
E-
E- (setSkillPath ". C:/Users/USER1/AppData/Roaming/SPB_Data/pcbenv C:/Cadence/SPB_17.2/share/local/pcb/skill C:/Cadence/SPB_17.2/share/pcb/etc")
E-        ^
E- SYNTAX ERROR found at line 1 column 73 of file *string*
E- *Error* lineread/read: syntax error encountered in input
W- *WARNING* (reader): string terminated by illegal char \320 at line 4 of file allegro.ilinit
E-
E- DstCMOIlinitPath = "C:\\Users\\USER1\\AppData\\Roaming\\SPB_Data\\pcbenv"
E-        ^
E- SYNTAX ERROR found at line 4 column 78 of file allegro.ilinit
W- *WARNING* (reader): string terminated by illegal char \320 at line 5 of file allegro.ilinit
E-
E- DstCadenceMODashboard = "
E-        ^
E- SYNTAX ERROR found at line 5 column 75 of file allegro.ilinit
E-
E- C:\\Cadence\\SPB_17.2_Manufacturing_Option\\Documentation Editors\\CDNDashboard.exe"
E-                      ^
E- SYNTAX ERROR found at line 6 column 22 of file allegro.ilinit
E- *Error* eval: undefined function - DstCadenceMOAddMenuItem
  • oldmouldy
    oldmouldy over 8 years ago
    Yes, this is a potential malfunction since it looks like your Skill Path won't be set to load any custom SKILL routines but, you may not care. It's possible that your Windows User name contains an illegal character, at least as far as PCB Editor is concerned. Start PCB Editor and use Setup>User Preferences, use the Search for Skill to locate Skill Path and edit the preference to remove the path with the issue. In recent versions Skill Path is no longer a preference so you may need to check the pcbenv folder for an allegro.ilint, or env, file which could be holding the setting (They are both text files)
