  3. Mechanical pins in symbol that are changed to normal pins...
  • Views 13332
Mechanical pins in symbol that are changed to normal pins do not update.
Lennie
Lennie over 8 years ago
I have a symbol that had 9 mechanical pins. I changed them to normal pins and when I update the symbol the mechanical pins do not update.
  • steve
    steve over 8 years ago
    This is more than likely because if the pins are now normal they will be driven from a pin on a symbol in the schematic. You will need to update the schematic to add the extra pins then update the netlist and import. You may also need to delete the part and then re-place it
  • steve
