  3. PCB Layout and Schematic capture suite availability for...
  • Views 16417
PCB Layout and Schematic capture suite availability for Linux environment
jayaura
jayaura over 8 years ago
Last post regarding the same was about 4 years ago. Are there any products from cadence which covers Schematic Capture and PCB Layout which works in Linux ? If available, how can I get a trial version  ?
  • UlfK
    UlfK over 7 years ago
    Not exactly an answer to your question but: If you get such a version, know then that only SUSE or RedHat was supported when we tried to install a full version some years ago. Not even Fedora worked. If you want to use it with eg. Ubuntu I doubt that it will work.
  • jayaura
    jayaura over 7 years ago in reply to UlfK
    Most commerical vendors, if at all they support Linux, it will usually be RHEL or suse. I wont be surprised. But how was your experience? Is it exactly the same Windows version? What were your reasons to go with Linux version ?
  • UlfK
    UlfK over 7 years ago in reply to jayaura
    We tried installing it to a Fedora system (which is the free but unsupported version of RedHat) but failed. Installing Redhat was no option for my co-worker.
  • jayaura
    Fedora is pretty bleeding edge, and is not binary compatible with RHEL. But CentOS is. Any software that works on Rhel must work on Centos as well,since they only differ in branding. Everything else as far as a software that runs on it is concerned, is the same. If you or your co worker feels like giving Linux env another shot, please try the corresponding CentOS release. Usually software on linux is much more snappier, which is the reason why I would prefer Linux.
  • UlfK
    Ah...
    Downloaded the 17.20 Linux Version.
    We'll give it a try.
