  3. Allegro 17.2 test point creation
  • Subscribers 163
  • Views 14995
tracemhos
tracemhos over 8 years ago
Curious to know why the test point NC drill exports in english units even with the NC parameters specifies metric?
Also not a fan of having to use separate test point pads for top and bottom test points as opposed to just using an SMD pad and mirroring to the bottom. Seems like this could be made much better
  • riklee
    riklee over 8 years ago
    Using 17.2 S031 and I am not seeing the units reported in the drill file not change to what the parameters are set to:
    Using MILS data
    < MECHANICAL PIN >
    location-xy: (2525.0 3275.0)
    An English drill file exports the location as
    M00
    X002525000Y003275000
    That same hole with the parameters set to Metric and the DB still using MILS
    M00
    X064135000Y083185000
  • tracemhos
    tracemhos over 8 years ago in reply to riklee
    The normal drill file shows the correct units, its the test point drill file that doesn't change its units
