  3. Deleting a Dimension "WARNING: Dimension point at (375.00...
  • Views 1424
Deleting a Dimension "WARNING: Dimension point at (375.00 5600.00) is unassociated with an object."
FormerMember
FormerMember over 7 years ago
I'm trying to delete a dimension that is not associated with an object.  I have tried using the Dimension Environment and the Delete Dimensions select from the drop down, but it will not delete.  Any ideas on what I can do to make this go away?
Thanks!
Susan
  • DaveatUD
    DaveatUD over 7 years ago
    Hi Susan,
    Make your schematic page bigger than 5600.00 wide using a custom page size. You will then be able to zoom out then zoom in to the coordinates 375.00 5600.00...You ought to then be able to see the object causing the error & delete it.
    regards, Dave
  • FormerMember
    FormerMember over 7 years ago in reply to DaveatUD
    Hi Dave,
    So sorry I forgot to mention this is a Layout issue.  I'm running 16.6.  I did a dimension, realized I wanted the decimal place to be 3 instead of 2, changed the design perimeters to match what I wanted.  Clicked on it to delete it and now stuck with it still at 2 decimal places, all others changed to 3 as I intended.  I can't delete it, I can run down the list and show the properties on it and it says it isn't attached to anything. Thank you for your help!
    Susan
  • DaveatUD
    DaveatUD over 7 years ago in reply to FormerMember
    Hi Susan,
    I should have known that from your description (dimension environment)...Still, you have it sorted out now. Good.
    Yea - what a program!
    Layout, PDB Designer, Capture - they all cost $$$$'s & all have serious long standing bugs that have never been fixed!
    Regards, Dave
  • DaveatUD
    Hi Susan,
    Regards, Dave
