  3. analylis bus in SigXplorer
  • Replies 7
  • Subscribers 162
  • Views 18411
archive over 21 years ago
Hello!
I want to analyse reflection for several signals or bus (for example, bus data, bus address).
for single signal sigxplorer can perfom this analysis, but How does perfom analysis for several signals or bus in Sigxplorer?
Docunent SigXplorer User Guide has description for Measurement Expression Editor. How can I open it editor? and in what program I can open it editor Alegro or SigXplorer?
Originally posted in cdnusers.org by serg_sv
    SigXplorer isn't the proper tool to be doing bus analysis. Allegro PCB SI (aka SPECCTRAQuest) has the ability to run batch simulations of multiple nets. If you are looking at just the reflection of these a bunch of nets, then the report mechanism from the Probe form would be your best tool. It isn't meant for what if analysis, but rather for simulations of routed (or unrouted if you desire) nets.
    If you want to do xtalk analysis of coupled lines in SigXP, then you would use the coupled line elements from the library. You can then sweep things like the trace spacing, dielectric constants, etc.
    The Custom Stimulus editor is built into SigXP. From the Measurements tab, you select Custom, then look at one of the default ones (like DieNoiseMarginHigh) to see the syntax. An app note can be found at:
    http://www.cadence.com/community/allegro/Resources/resources_pcbsi/si/HowTo_custom_measurements.zip
    Originally posted in cdnusers.org by horner
    Hello John Horner!
    Thank you for your answer. I can't download HowTo_custom_measurements.zip. If don't difficult, Can you send it to me by mail: sergey-r@bercut.ru.
    I don't understand about which library for coupled line elements in xtalk analysis you speak.
    Kind Regards,
    Sergey
    Sergey,
    Please explain why you cannot download the file John recommends. It is a small zip file and should be downloadable.
    Moderator
    Originally posted in cdnusers.org by Moderator
    I have used Reget Deluxe 3.2 for download files. But Reget after several try write me, that cannot download it zip file and give next error: (No connection could be made because the target machine actively refused it.)
    Segey.
    Posted By serg_sv on 3/14/2005 12:12:09 AM
    Sergey.
