  3. 【Help】Failed to create netlist : Error ORPXLL~1
  • Subscribers 163
  • Views 2995
xiaoyi594
xiaoyi594 over 8 years ago
Hi ,there,
My ORCAD runs well recently , but all of a sudden, today I got some error when trying to creat net list. Could anyone help on this? I really do not want to reinstall Cadence 16.6
Following is Netlist setup(default as usual) and Error Screen shot. In the error picture, after I click OK, Cadence stopped responsing and stucked, so I have to end it in windows task manager.
Thanks very much!
  • xiaoyi594
    PS: The last Chinese words in second picture is "Access Denied " or ( Refuse to access )
  • xiaoyi594
    This situation happens to any SCH files, and I checked on my colleague's computer that SCH files are ok, which can create netlist on their Cadence. So I think it is something wrong with my Cadence 16.6.
  • oldmouldy
    oldmouldy over 8 years ago in reply to xiaoyi594
    You should find some other posts on this topic but I seem to remember that starting Capture with the right-click>Run as Administrator option once would get the components registered and create the netlist from then on. You might also want to check that you are on the latest hotfix, 16,6-2015.s104 is current I believe.
  • xiaoyi594
    xiaoyi594 over 8 years ago in reply to oldmouldy
    hi oldmouldy, I tried starting Capture with the right-click>Run as Administrator, not work. Could you help find other posts on this topic? Thanks.
