  3. Differential Pair to Pair Spacing
  • Subscribers 166
  • Views 17672
ToddR
ToddR over 7 years ago
I want my diff pairs set up as follows. (8 layer PCB) Allegro 16.6
Top and bottom 5.5mil width with a 10mil space
L3 and L6 5mil width and a 7mil space
I need 30mil PAIR TO PAIR
PROBLEM: When I set 30 mil as my min space I get DRC's within pairs because their spacing is 7 or 10.
I only get this problem on layers 3 and 6, Top and bottom diff pairs route as expected 10 mil space and 30mil pair to pair.
Any ideas?
  • oldmouldy
    oldmouldy over 7 years ago
    Add a Net Class Class for the Diff Pair Class to Diff Pair Class and apply the required Spacing rule to the CCls in Spacing.
  • gowthaman90d
    gowthaman90d over 7 years ago
    ToddR,
    Have you defined minimum line spacing of diff pairs? Try setting minimum line spacing equal to primary gap ow with any tolerance.
    It will override the 30 mil spacing constraints within the pair.
    Gowthaman
