  3. Assign net to cline?
  • Subscribers 166
  • Views 16036
stewartshearer
stewartshearer over 7 years ago
I have a design that had to be converted to our internal CIS database. In doing so, many of the footprints where slightly different. The result is that nearly every net in the design is no longer connected to its respective clines.
Is there an easy way of re-associating the cline segments to their respective nets?
  • excellon1
    excellon1 over 7 years ago
    Hi
    Did only the footprint name change on the schematic symbol or did the net names on your schematic also change. ?
    Paul.
  • steve
    steve over 7 years ago
    Try Tools - Derive Connectivity then check all the boxes and see if that helps.
