  3. How to find Cadence install location in 17.2?
  • Subscribers 167
  • Views 15937
EvanShultz
EvanShultz over 7 years ago
SPB 17.2 has removed the CDSROOT env var, which I'd used to determine the installation folder. I used it in a post-install script which configured users' PCs.
Is there a way to determine the install location in 17.2? For now if the env var was blank I just input a text string, but that's ugly and a pain to maintain.
Thanks!
  • steve
    steve over 7 years ago
    17.2 doesn't need this anymore - it doesn't use the PATH variable but there is no reason why you can't simply add it back in again....
  • oldmouldy
    oldmouldy over 7 years ago
    If you really need the installation location, it's in the registry. For All Users installation this is in HKEY_LOCAL_MACHINE\SOFTWARE\Cadence Design Systems\SPB 17.2\Targetdir but it will likely be in HKEY_CURRENT_USER\SOFTWARE\Cadence Design Systems\SPB 17.2\Targetdir for a This User Only installation, use the "reg query" command at the Windows Command Prompt to get the value.
