  3. Creating a Board outline
  • Views 17567
HSID
HSID over 8 years ago
I am trying to create a board outline and would also like to know how once I have created the board outline how to bring it in to associate it with the actual design.
I would like to draw a rectangle shape and then edit the size, is this possible. The manual shows entering in specific coordinates but at this point I would like to draw a rectangle and edit the dimensions once I receive them from my mechanical group.
Once I have the board outline drawn how do you bring this into a design.
Can you create a board outline template and then edit this template to fit your current design.
HS
  • tmd63
    tmd63 over 8 years ago
    There are a number of methods you can use. Are you using Allegro PCB Editor or Orcad Layout?
    We use AutoCAD to create the board outline. Then we save as a Revison 12 DXF. and use the DXF import to bring the layer information into Allegro PCB Editor.
    Notes: The outline MUST BE a closed pline. Use a single layer for board outlines and use the layer conversion table to get it into the correct layer (class and subclass).
  • HSID
    HSID over 8 years ago in reply to tmd63
    Thanks, that helped
