  3. "Attribute "CDS_DI_CONTROL_MASK" is not defined." Allegro...
  • Views 4293
"Attribute "CDS_DI_CONTROL_MASK" is not defined." Allegro HDL crashes
PaoloUoB
PaoloUoB over 7 years ago
This require a little explanation.
At work we have floating licenses for Allegro HDL, recently upgraded to 17.2.
I generally work on projects from my Windows 7 pc but a colleague uses various Linux computers to access the same projects.
So far everything went (more or less smoothly).
A few months ago I created a new project, including the schematics, exported to PCB and placed the board. When the board was almost ready to go to manufacturing, the colleague decided to optimize some stuff, including replacing some capacitors using the Edit > Global Update > Global Component Change... function.
I think this broke something for me because now I can no longer open the schematics: when I do I immediately get an error window saying
"There was 1 warning while reading XXX.dcf file. See XXX_dcf_read.log for details.
Then the software crashes and I need to close it from task manager.
The content of the log file is
Problems encountered while reading "P:\cad\designs\XXX\sch_1\XXX.dcf" Read: Wed Feb 14 17:58:07 2018
Warning:     Attribute "CDS_DI_CONTROL_MASK" is not defined. Failed to create "CDS_DI_CONTROL_MASK" attribute for object Design "XXX"
The DCF file is present in the sch_1 folder and I have access (rwx) to it so it is not a permission problem.
I should also mention that I can open the file with no issues from a Linux computer, so it seems to me that there is a problem with a PATH not being defined correctly but, as much as I looked into this, I could not locate the issue.
Can anyone provide some guidance as to what has gone wrong? Any tip on files or paths to check would be really welcome.
  • PaoloUoB
    I should also mention that I can work on any other project without this issue occurring, so it really is something related to this specific design.
  • oldmouldy
    oldmouldy over 7 years ago in reply to PaoloUoB
    According to the Cadence Support site, this is an issue when different early, pre hotfix 11, versions of 17.2 are mixed and was fixed in 17.2 hotfix 11, current version is 17.2 hotfix 34. Getting both installations to the latest hotfix should fix this.
  • PaoloUoB
    PaoloUoB over 7 years ago in reply to oldmouldy
    Thank you very much, it worked.
    I installed the latest hotfix and I can now open the project again.
