  3. How to add Mechanical Symbol to Drill Chart?
  • Views 13613
AndresL
AndresL over 7 years ago
I have a mechanical symbol for a #4 hole non plated mounting hole.
After I'm done routing I added them by going to Place > Mechanical Symbol as needed and created the drill chart table. However, I can't see the mechanical holes on the chart, only the holes from vias or components.
How can I add the mechanical mounting holes to the drill chart?
  • redwire
    redwire over 7 years ago
    Make sure that the symbol has a padstack.  A padstack can be a mechanical drill (non-plated or plated) but it won't appear in the drill chart if no padstack is present.
  • redwire
  • AndresL
    AndresL over 7 years ago in reply to redwire
    The mechanical symbol is a Padstack (defined as a mounting hole) with some silksckreen, but it still won't appear on the drill chart.
    I changed the padstack to be a mechanical hole instead of a mounting hole and that fixed my problem
