  3. How to remove unused parts from an Allegro 16.6 PCB fil...
  • Views 21948
How to remove unused parts from an Allegro 16.6 PCB file
tmd63
tmd63 over 8 years ago
I have an Allegro PCB Editor file that has a mechanical part that was added but then not used.
But the IPC output refuses to complete because this unused part still exists in the PCB editor file database, even though it is not used. Dbdoctor refuses to remove the part! How can I clean up the Allegro PCB Editor database file to only have used parts stored?
  • redwire
    redwire over 8 years ago
    I might be missing something...but can't you just delete the unwanted part?
  • tmd63
    The part was selected for inclusion in a design and placed on the design. But then it was deleted as it was the wrong item.
    The part no longer appears on the design but is still loaded in the database as library parts are copied to the design database.
    It is the fact the party is still loaded in the database that is causing us issues when generating IPC outputs. We need to PURGE the database of all unused parts but there is no method to do this!
  • steve
    steve over 8 years ago in reply to tmd63
    So was this part in the schematic? If so, delete from there and recreate and import the netlist into Allegro and it will be gone. If you can't do that (and that is the recommended way) try Logic - Part Logic (you will need to enable this) and locate the part there and delete it.
  • tmd63
    tmd63 over 8 years ago in reply to steve
    The part is a Mechanical Part and not in the Schematic.
  • steve
    Then use Edit - Delete and remove it. Make sure it's not fixed. If you can't do this try a DBDoctor
