  3. 3D via model
  • Subscribers 162
  • Views 14458
3D via model
archive over 21 years ago
On page 258 of the PCI SI Simulation Reference manual there is a brief discussion of Closed form via models and 3D field solver generated via models. A brief set of instructions were provided describing how to use PCB SI to build a more accurate via model using the built in 3D field solver. I followed those steps, but was not able to generate a new model. Could someone confirm that PCB SI has this capability, and then give further explaination on how to generate the new via model?
Ken
Originally posted in cdnusers.org by kholmanbb
    Ken, Basically there are 3 different styles of vias in the tool. The simple closed form , detailed closed form and 3D.
    If you choose the detailed closed form option it actually runs the FSVia routine to get a pretty close result to the more computationally intensive 3D solver.
    Now there is a variable "Set_3D_Via_Solver 1" (set this in the pcbenv\env file) that will force the fsviasolver executable to be run for all the extracted vias. This is much slower, and we have found to be not much more accurate then the detailed closed form results. This solver isn't officially supported right now however.
    Refer to Solution 11098106 on Sourcelink for some more info.
    Also, you can type in FSvia with no arguments at a command prompt to get additional information.
    Originally posted in cdnusers.org by horner
