  3. How to put via in the center of BGA pins
  • Subscribers 163
  • Views 17055
ColinLiu
ColinLiu over 8 years ago
Hi sir,
How to put VIA in the center of BGA pins in below case. You can see Distance a is smaller than b.
When i set Route/create fanout/ pin via space-centered, it put the via as picture shows.
It seems it is just the center of distance a. But I think it is better to put via in point C.
I can not find easy way to put it. And I am afraid it is not exact center If i move it by manual .
Is there any proper command to achieve it?
  • steve
    steve over 8 years ago in reply to ColinLiu +1
    The only choice you have is to add one via based on the centre (draw a line from pin to pin diagonally then add the via using right click - snap pick to - segment midpoint) then once you have one create…
  • oldmouldy
    oldmouldy over 8 years ago
    It doesn't look like dimensions "a" and "b" are the same. A BGA fanout would be expecting a regular X / Y matrix and being able to use a 45 degree "dogbone".
  • ColinLiu
    ColinLiu over 8 years ago in reply to oldmouldy
    thanks,sir.
    yes, the distance a is not the same as distance b. do you means it is not proper to using FANOUT in this case? and what is the proper command in this case?  i am afraid it is not exact center if add vias by manual and adjust it to the center by observe. what is your normal pratice?thanks.
  • steve
    The only choice you have is to add one via based on the centre (draw a line from pin to pin diagonally then add the via using right click - snap pick to - segment midpoint) then once you have one create a via structure (Route menu) then use that for the fanout tool.
  • ColinLiu
    ColinLiu over 8 years ago in reply to steve
    Thanks steve, I got your point. And create such via structure successful.
  • riklee
    riklee over 8 years ago in reply to steve
    top shelf
