  3. Counter Bore/Sink From Opposite Side
  • Views 2729
Khurram
Khurram over 7 years ago
Hi Folks,
Anyone use the new feature which allow you to define the counter bore/sink in the Padstack editor?
Right now it is allowing you to define it from Top side but if i need it to define from bottom side, then what i need to do?
Khurram
  • steve
    steve over 7 years ago
    Place the padstack that contains the counterbore / sink hole into a Mechanical Symbol, add keepout areas etc. as you would normally for a fixing hole, then when you place the mechanical symbol into a board file you can mirror this - hence the countersink / bore would be on the bottom side.
  • steve
  • Khurram
    Khurram over 7 years ago in reply to steve
    Thanks for your comment but doing so we have to change the library and there a great risk of making error with using that methodology.
    I am wondering why cadence provide the counter sink/bore from same side because most of the times we need these definitions from opposite sides.
    Khurram
  • eDave
    eDave over 7 years ago in reply to Khurram
    I raised a case for this last year. CCR #1602624 but the status is inactive
  • Khurram
    Khurram over 7 years ago in reply to eDave
    Thanks Dave
