  3. Adding non-linked RefDes
  • Subscribers 163
  • Views 13825
dgronlu
dgronlu over 8 years ago
How do I add text to the RefDes->Silkscreen Top or Bottom layers without attaching it to a component?
For instance I want to put a label on the board and then change it later, but if I assign it to some random component, changing the text later then causes that component's label to change as well.
Is there a best practice here? I want to be able to label my board but not have to add dummy components for every new piece of text I add.
David
  • riklee
    riklee over 8 years ago
    If I were adding a label to the board in silkscreen I would add it to the Board Geometry / Silkscreen class/subclass
