  3. How to Create a load profile
  • Views 13696
chadga
chadga over 7 years ago
I am using OrCAD pspice plus version 17.2, and am working on a design where i have to provide a load profile.
Ex: My input source is 28V DC supply. initially my load will have some voltage across it. After 1 minute i want my load to draw only 5V and later after 3 minutes it should draw 10V.
Is there any way where i can provide a profile in this manner.
Kindly help me on this issue.
Chadga
  • oldmouldy
    oldmouldy over 7 years ago
    You can't "draw" a voltage, you could draw a load current which results in a voltage. Maybe some more details are required to answer this?
  • chadga
    chadga over 7 years ago in reply to oldmouldy
    Hi Mouldy,
    Yes i want to draw current. How can it be done.
  • oldmouldy
    oldmouldy over 7 years ago in reply to chadga
    You could add an IPWL across the load, for example, takes T (time) and I (current) value pairs in the properties, which should be sufficient in this case. Note that the + terminal is the source and the - terminal is the sink for the current through the part.
