  3. Differential Pair Via Spacing
  • Views 17395
Sagetech
Sagetech over 7 years ago
When routing a differential pair and transitioning to another layer, the via spacing is wider then I would expect.
For example, I have the diff pair trace to trace spacing set for 0.3mm but the vias are being spaced 1mm apart. I have the via to via spacing set to much less then that in CM.
Where should I look for a setting that controls the via to via spacing on a diff pair?
Tom
PS Using 16.6 S102
  • Sagetech
    I believe I just answered my own question - while routing the diff pair RMB, then select via pattern>spacing the settings are available there.
    Interesting these settings don't seem to be available from CM unless I'm missing something.
    Tom
  • steve
    steve over 7 years ago in reply to Sagetech
    This is possible with the Allegro + High Speed option and the latest QIR for 17.2-2016 (s037). There's a video showing how to set this up https://www.youtube.com/watch?v=8P2ytJ8Y6vI&t=27s
