  3. Extract netlist on specific area
  • Views 13559
skuscu
skuscu over 7 years ago
I'd like to extract all the nets that is routed in a specific are on PCB on each layer. For example I have a component U10, and I'd like to see all the nets routed around it that is max 5mm away.
Is there any way to do it quickly?
thanks,
  • steve
    steve over 7 years ago
    Yes - create a place replicate module of the circuit you want which makes a filename.mdd. You can open this by File - Open then change the files of type to mdd and open this, then use Export - Netlist with properties
