  3. Using Variants in MCAD Export
  • Subscribers 166
  • Views 13410
Stefan Schrader
Stefan Schrader over 7 years ago
I would like to export 3D step files according to variants.
Is there any possibility to do so?
  • Dale Peterson
    Dale Peterson over 7 years ago
    Would be nice but not. However, You could manually unplace parts you don't want in your export. Also, for repeatably you could record a script to do the same thing.
  • steve
    steve over 7 years ago
    Yes - inside the 3D Canvas use the symbols tab to turn off the parts you don't want to export. Then use File - Export and change the files of type to STEP and export a STEP model of what is displayed. You may need to turn off certain layers because anything that is displayed in 3D will be exported. I will say that the file size can be large.
