  3. Step mapping
  • Views 14781
Step mapping
Emmett
Emmett over 7 years ago
I am trying to map a step model of an SMA from grabcad.
I clicked Setup, Step Mapping and get the Device/Package step mapping window.
I can see the name of and can visualize the step model, but not the symbol,
Now what?
Emmett
  • steve
    steve over 7 years ago
    Try clearing the filter for available packages and see if that shows. If not, are you in a filename.dra? If so make sure you have a PLACE_BOUND_TOP shape. You can also click on the Overlay button and change the Views to see if this helps.
  • Emmett
    Emmett over 7 years ago in reply to steve
    Hi Steve,
    Thanks for the reply.
    I did have the dra open at the time, but could not see the place bound.
    The next day, I could.
    Maybe closing and re-opening the dra or app or the re-boot helped.
    I think I got it done, but I still expected to see all the available symbols that have no step map associated.
    Also for us newbies: you can't see the pads except in bottom view.
    Emmett
  • steve
    steve over 7 years ago in reply to Emmett
    So if you open a board file you will see a list of symbols that don't have step models. if you open a filename.dra you are only looking at that specific part so will only see the packages list s empty because you are working on just that part. I can see pads in top and bottom views so if you can't first make sure you are running the latest hotfix 16.6-2015 S108 and 17.2-2016 S039.
