  3. Doube symbol
  • Views 13949
Doube symbol
Filo88
Filo88 over 7 years ago
Hi guys,
i have a new question. Is possible in capure cis to have a doube symbol?
For example about connector. For a one project schematic (core desine) i can to have more different versions and more configuration of PIN.
In the version "A" the PIN1 is a "IN" and in version "B" the PIN 1 is a OUT
When i swich versione i would like that simble of PIN 1 is different respect the simble the pin 2 for  highlighter input and output. How can I do this?
  • SteveNZ
    SteveNZ over 7 years ago
    Hi, if you want to have two different schematic symbol choices for one part you can add the "|" symbol (this is on \ key) as a separator between the two different schematic symbol names. IE. CAP0603|CAP0603_Ver2.
    In CIS explorer you will now see a drop down box in the schematic field where you can select either symbol. You can actually have more than two different symbol choices.
  • Filo88
    Filo88 over 7 years ago in reply to SteveNZ
    Thanks for you reply, but where I have to put the second symbol (IE. CAP0603|CAP0603_Ver2 )? In the library o in an property in the schematic?
  • SteveNZ
    SteveNZ over 7 years ago in reply to Filo88
    I add the "|" at the database level. There is a field for the schematic symbol name. Are you able to access the database itself?
  • Filo88
    I tried to put the symbol "|"  in the database level but it does not work. It works if I put the "," (IE.CAP0603, CAP0603_Ver2). Thanks for your suggestion but it isn't exactly that i want.  The my problem is about  connectors.  For example:
    For an connector of 10 pins, I create a multiple -part-package of 10 parts. I put this parts in the schematic, some in the page 1 and other in the page 3 o 4.  I would like to add one property that discriminate the IN or OUT for every pins. Is possibile this?
  • LouShay
    LouShay over 7 years ago in reply to Filo88
    Hi Filo88,  Since each of the 10 heterogeneous symbol portions will have its own pin (1-thru-10) couldn’t you simply define the pin type (IN/OUT) for each one?
     Regards,   -lou
