  3. Copper plane with complex shapes
  • Replies 12
  • Subscribers 169
  • Views 16275
albertopv
albertopv over 7 years ago
Hello all,
I need to create a copper plane in a relatively complex shape for my actual design. I have tried without any success importing a .dxf File with the shape description, as the tool only seems to work properly with outlines and not with surfaces.
The shape is something similar to this:
Do you have any idea on how I could achieve this?
Thank you very much in advance! Slight smile
  • steve
    steve over 7 years ago
    I'm sure if you export a simple dxf you can import this shape so can you post the dxf file? The alternative is to use the Add commands with the Manufacture - Drafting options to construct this.
  • albertopv
    albertopv over 7 years ago in reply to steve
    shape.zip
    Hello Steve,
    thank you very much for your fast reply. This is the dxf file which I am using without success.
  • steve
    steve over 7 years ago in reply to albertopv
    OK so as I said this dxf contains complex items (polylines). I opened this in draftsight and resaved as a R12 ascii dxf, you can then import that. shape1.zip
  • UlfK
    UlfK over 7 years ago
    The .DXF needs to be a closed polyline in order to translate correctly into a shape.
    I have always advocated the opinion that a mech tool that can create or modify mechanical or other arbitrary
    figures that is to be imported into the PCB editor is a necessary companion since many mech tools that can output
    data into .DXF can do so while also adding 3D data that the PCB editor cannot understand and hence discard
    the import file completely. You will need to rotate, flattern, create polylines and also modify the extents and the
    contents of the various layers that comes with the .DXF. Personally, I use AutoCAD but there are other tools
    that can do this.
  • albertopv
    Very nice! Unfortunately I am working with the version 16.6 and I cannot open that design but I will convert my files to the format you mentioned Slight smile
