  3. path name wildcard syntax
  • Views 13486
Emmett
Emmett over 7 years ago
I am a newbie w/ SPB17.2 and latest hotpatch.
I created a separate directory for my symbols.
Under that directory I have sub-directories by category.
I can place those symbols if I list each sub-directory in the psmpath, etc.
Is there a wildcard syntax so that I can just list my global symbols directory in the path?
In other words, so that I don't have to list every sub-directory? (I will be adding new sub-directories frequently)
Emmett
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Emmett,
    I don't think Allegro allows any wildcards in their library paths :(
    However, I wrote the following in my allegro.ilinit this morning which resolves that issue by expanding * wildcard into actual sub-directory folder entries:
    procedure( MyTriggerOpen( t_open)
    let( (TmpStr TmpPath NewPath)
    foreach(Directory parseString((axlGetVariable "PSMPATH"))
    if(nindex(Directory "*") then
    (TmpStr = substring(axlOSSlash(Directory) 1 strlen(Directory) - 2))
    when(isDir(TmpStr)
    foreach(subdir getDirFiles(TmpStr)
    unless(nindex(subdir ".")
    (TmpPath = strcat(TmpStr "/" subdir))
    when(isDir(TmpPath)
    if(NewPath then
    (NewPath = strcat(NewPath " " TmpPath))
    else
    (NewPath = TmpPath)
    else
    if(NewPath then
    (NewPath = strcat(NewPath " " Directory))
    else
    (NewPath = Directory)
    axlSetVariable("PSMPATH" NewPath)
    t
    axlTriggerSet('open 'MyTriggerOpen)
