  3. how to output a gerber file of drill?
  • Views 15260
Zhiwei Tu
Zhiwei Tu over 7 years ago
Hi All,
I am looking for a single drill file. I can find it in AD, but I can't find it in allegro.
We can get a NC drill file (I call it file1) by "Manufacture"->"NC"->"NC Drill".
Select as the following figure,and create artwork.We can also get a via file(I call it file2).
but geometrical figure in file1 and file2 are not the same - only smaller circle in NC drill(this is what I want)
when I open file1 and file2 together, I see following fig. Yellow circles are in file2(we can see more then 1 circle in each yellow figure). Blue circles are in file1.
I want to know if I can find this single drill file. If so, what should I do?
Thanks in advance.
  • redwire
    redwire over 7 years ago
    There are two files needed.  One is "drill" which is generated as you mention above by "Manufacture"->"NC"->"NC Drill".
    That is the blue figure.  The other layer is copper which is from artwork (Gerber) output.
    Or you can save yourself a bunch of headaches by using ODB++
  • Zhiwei Tu
    Zhiwei Tu over 7 years ago in reply to redwire
    hello redwire
    Yes,I can get the blue figure in odb++ file and NC drill file.But I want a gerber file which includes drill geometrical information.
    I output a gerber file(file1)  for via as I mention above. Only copper pad in file1.  This is too strange. Obviously gray drills can be seen.
