  3. MODEL selector in IBIS
  • Views 16889
archive over 20 years ago
Hi
I am somewhat confuse about Model selector keyword in IBIS.
How can it will be useful it in spectraquest?
Originally posted in cdnusers.org by naren_thesia
    When you have the model selector set up in IBIS, ibis2signoise will translate them into DML automatically.
    Assign this model to a part in Allegro PCB SI. In the model assignment dialog, click RefDesPins. Next to "Signal Model" field, there is "Prog. Buffer ->". You should see the programmable buffers (Model Selector) right there.
    Attached a bmp file to show how it looks like.
    Hope this helps.
    Lance Wang
    Originally posted in cdnusers.org by lwang
    mdlassign.zip
    Thanks iwnag
    Dear Lance
    Thank you for your answer. We realize the model selection feature in PCB SI. How about the feature of multiple-pin model assignment? It means we need to assign the same kind of buffer model for many pins in one time. Thank you for your helps in advance.
    BRs,
    Sogo Hsu
    Originally posted in cdnusers.org by sogohsu
    Sogo,
    At this time, you have to do this pin by pin.
    Id this often heppenning to a lot of pins set together?
    Lance
    Dear Lance.
    Sure. You can image if your would like to perform corner test for FSB. There are totally 64 data bits plus 4 strobe lines. The feature is indeed necessary.
    Sogo Hsu
