  3. Regarding SI230 OR 610 FEATURES
  • Subscribers 162
  • Views 15047
archive over 20 years ago
Hello all,
i was looking the data sheets Comparision of SI210 230 AND 610 CAN ANY ONE TELL ME WHAT THE BELLOW FEARUEWS MEANS
1) BATCH SIMULATION
2) DIFFERENCIAL SIGNAL CONSTRAINST CAPTURE
3) COUPLED LINE SIMULATION
4) CROSSTALK SIMULATION ( WHICH NOT THERE IN 210 AND PRESENT IN 230)
PLS REPLY FOR THIS IT IS IMPORTANT FOR ME.
ALLEN
Originally posted in cdnusers.org by allen
    Allen:
    The biggest difference between 230 and 610 is that 210 lacks the autorouter and you won't get real time "red" or "green" flags if you are manually routing and you violate or meet constraints. 230 is fine for most pre- and post- layout analysis work. 210 is a subset of 230 which does not let you define constraints for board files. It is good for exploratory work but not really useful in the full design flow.
    You should probably start with 230 if you want to see how the tool can fit into your Allegro design flow.
    Originally posted in cdnusers.org by Kalevi2
    Allen:
