  3. My PCB Manufactuer claims my drill file is empty
  • Views 15917
James4235
James4235 over 8 years ago
Hello, I've followed the tutorial here to generate my drill file http://referencedesigner.com/tutorials/allegro/allegro_page_9.php and I have even viewed the drill file on an online gerber viewer and I can see the holes, however, my manufacturer (ALLPCB) says the drill file is empty. I have attached my drill file to this link https://ufile.io/r9pb4, can anyone spot anything wrong with it? Many thanks.
  • excellon1
    excellon1 over 8 years ago +1
    Hi James, I can confirm your drill file is not empty but what's going on is more than likely their tools are choking on what Allegro is putting out. Try this. NC Parameters: Enhanced Excellon Checked…
  • excellon1
    Try this.
    NC Parameters:
    Enhanced Excellon Checked "Believe you have this checked"
    Trailing zero suppression checked.
    Coordinates = Absolute
    Output Units = English
    Format = 4 4 "Your format may be different"
    Offset x, y = 0
    NC Drill
    Auto Tool Select Checked "Your file looks like it has not got this enabled"
    Repeat codes Checked
    Optimize drill head travel.
    After you generate the NC file, check the log. (View Log Button)
    I did some tests with a high-end, industry standard gerber editor that is capable of pulling in NC drill files. When using Enhanced Excellon format and if "Auto tool Select" is not enabled The gerber editor will not import the allegro NC file. "Probably an Allegro Bug"
    Give the above a try and see if all is working.
    Paul.
  • James4235
    James4235 over 8 years ago in reply to excellon1
    Hi Paul, I followed your steps and the PCB manufacturer has now approved the PCB for fabrication, thank you for your help!
  • excellon1
    excellon1 over 8 years ago in reply to James4235
    Sounds good James.
    Glad that worked out
    Paul
