  3. Differential Pair Resize and Respace
  • Views 17092
Avalex Steven
Avalex Steven over 7 years ago
Is there a way to resize and re-space already routed differential traces other than re-routing them?  I've had to change my stack up late in the game and now need to adjust a large number of already routed differential pairs.
  • steve
    steve over 7 years ago
    Yes - look under the Route - unsupported prototypes menu for Resize/Respace Diff Pairs then follow the GUI. This won't change Constraint Manager so you can either change that first then run this or vice versa.
  • Avalex Steven
    Avalex Steven over 7 years ago in reply to steve
    I don't see that on my menu, what version are you running?
  • steve
    steve over 7 years ago in reply to Avalex Steven
    Allegro PCB Designer 17.2-2016 S042 (so the latest). What do you have?
  • Avalex Steven
    OrCAD PCB Designer Professional 17.2-2016 S042
  • steve
    You'll need at least an Allegro PCB Designer license to be able to do this. Maybe talk to your channel partner and see if you can get a trial license.
