  3. Variants: why all attributes of a component are visible...
  • Views 13419
Variants: why all attributes of a component are visible?
Steno
Steno over 7 years ago
Hello to everyone, I am new with Cadence and I am having some troubles with Variants...
I made a Variant for a resistor with a different value and the schematic and the BOM are ok, but I don't understand why, in the schematic, all attributes of the component involved in the Variant are shown visible
(normally, when I see the "Base" schematic, only the ref-des is visible).
Is it normal? How can I avoid this problem? I would like to see only the ref-des and not all the other attributes...
Thank you for your help!
  • Steno
    I found this environment variable "CDS_VARIANT_PROP_VIS" in Cadence Help and it seems the responsible of my problem (all attributes that appears in the schematic are "variant properties"). I have added this environment variable in the "Advanced system settings" (Window 7 64bit) but nothing change....
    Do you know if there is something else I can do?
    Thanks for your help
  • Steno
