  3. Orcad library to concept symbol conversion
  • Replies 7
  • Views 17465
narapara1
narapara1 over 7 years ago
 How to convert OrCAD library parts to concept library parts, all at once not part by part.
 Thanks in advance.
Raghu
  • rads
    rads over 7 years ago
    Hi Raghu,
    There is no way to translate all OrCAD library parts to concept library at once. You can do it on part by part basis using File->Import->Capture Part (Windows only) in Part Developer.
    Rads
  • Kirti Sikri
    Kirti Sikri over 7 years ago
    You can run a cap2con to convert all parts of Orcad Library to concept on DOS command prompt
    ex to convert a.olb to cells in concept/abc
    cap2con -proj cap2con.cpm -olbpath a.olb  -alias asprimitives  -cdslib cds.lib -conceptlib abc -product pcb_librarian_expert
    You need to create cap2con.cpm  similar to one shown below
    START_GLOBAL
    design_name 'dummy_root_design'
    design_library 'cap2con_lib'
    temp_dir 'temp'
    cpm_version '17.2'
    END_GLOBAL
    START_PDV
    Symbol_GridSize '0.100000000'
    END_PDV
    cds.lib
    DEFINE cap2con_lib worklib
    DEFINE abc ./concept/abc
    Directory worklib temp should exist
    Create directory concept/abc
    Cells in A.olb will be created in concept/abc
    Note: Cell might have characters like #20 which is hex character for space for example cell FILTER BPF LFB212G45SG8A192 in concept will be filter#20bpf#20lfb212g45sg8a192
  • narapara1
    narapara1 over 7 years ago in reply to Kirti Sikri
    Hi Kirti,
    It looks i am missing something, can you please check and let me know.
    cap2con C:\Users\xx\Documents\cap2con\cap2con.cpm C:\Users\xx\Documents\X\CADLibraries\OrCAD_CIS_Database\a.olb  -alias asprimitives  C:\Users\xx\Documents\cap2con\cds.lib C:\Users\xx\Documents\cap2con\concept\abc C:\Cadence\SPB_16.6\tools\fet\bin\concepthdl.exe
    Raghu
  • luvishis
    luvishis over 7 years ago
    Elgris Technologies (www.elgris.com) can convert OrCAD library to Concept library and can convert Concept library to OrCAD library
  • Kirti Sikri
    Kirti Sikri over 7 years ago in reply to narapara1
    The command line parameters are not correct, there are no options (given by -).
    For example, the -proj option is not there to specify the project file.
    Command line parameters of cap2con are given below
    Secondly, Why are specifying C:\Cadence\SPB_16.6\tools\fet\bin\concepthdl.exe
    You need to specify the pcb_librarian_expert as given below
    cap2con
    [-proj <path_for_proj_Lib>/<proj_file_name>.cpm]
    -cdslib <path_for_cds.lib>/cds.lib
    -conceptlib <destination_design_entry_HDL_lib_name>
    -olbpath <source_capture_lib_path>/<library_name>.olb
    [-part <capture_part_name>]
    [-alias {ascells|asprimitives}]
    [-overwrite]
