  3. PCB Editor: how to change mapping of mouse wheel?
  • Views 17208
dontpanic
dontpanic over 7 years ago
Hi! I want to change the mapping of the mouse wheel. Actually, I would just to invert it's current behavior (e.g. to match Cadence IC tools like Virtuoso):
-Wheel-down should be zoom OUT
-Wheel-down should be zoom IN
...where and how can I change these bindings? In virtuoso these are defined through "bindkeys". How is this handled in PCB Editor?
Thanks and regards,
Jorge.
  • oldmouldy
    oldmouldy over 7 years ago
    Here are the defaults from the installation env file:
    button wheel_up "zoom in $buttonfactor"
    button wheel_down "zoom out $buttonfactor"
    simply swap the "in" and "out" in these settings and add this to you own env file in the <home>\pcbenv\env file, or in you site file, if you have one. (buttonfactor is a User Preference)
  • dontpanic
    dontpanic over 7 years ago in reply to oldmouldy
    Thanks so much; this is exactly what I meant to achieve!
  • dontpanic
