  3. berkeley spice to dml
  • Subscribers 162
  • Views 14461
archive over 20 years ago
How can I translate the following Berkeley Spice (.sp3) file so that I can use it in SigXp:
SUBCKT SRDA05-4 1 2 3 4 5 6 7 8
*       Model Generated by Eval Lab   *
*    Copyright(c) ON Semiconductor    *
*          All Rights Reserved        *
*     UNPUBLISHED LICENSED SOFTWARE   *
*    Contains Proprietary Information *
* Commercial Use or Resale Restricted *
* Model generated on Mar 6, 2002
* MODEL FORMAT: SPICE3
*     pin1  pin2   pin3   pin4   pin5   pin6   pin7   pin8
*node:  1     2      3      4      5     6       7      8
XD1  9  2  SRDA05-4-N
XD2 11  2  SRDA05-4-N
XD3 14  3  SRDA05-4-N
XD4 16  3  SRDA05-4-N
XD5  5 17  SRDA05-4-P
XD6  5 15  SRDA05-4-P
XD7  8 12  SRDA05-4-P
XD8  8 10  SRDA05-4-P
XDT  8 13  SRDA05-4-T
L1   1  9  6.3NH
L2   4 16  2.9NH
L3   9 10  3.4NH
L4  11 12  3.4NH
L5   2 13  1.7NH
L6  14 15  3.4NH
L7  16 17  3.4NH
L8   6 15  2.9NH
L9   7 12  6.3NH
R1   2  3  1U
R2   5  8  1U
.ENDS SRDA05-4
.SUBCKT SRDA05-4-n 2 1
*      Model Generated by MODPEX     *
*Copyright(c) Symmetry Design Systems*
*      Which is The Property of      *
*     SYMMETRY OR ITS LICENSORS      *
*Commercial Use or Resale Restricted *
*   by Symmetry License Agreement    *
* Model generated on Mar  6, 02
*     anode cathode
*node: 2      1
*    Forward Section
D1 2 1 MD1 TEMP=25
.MODEL MD1 D IS=1.70021e-15 N=1 XTI=1 RS=10
+ CJO=1.5e-12 TT=1e-08
*    Leakage Current
R 1 2 7.2e+09 MDR
.MODEL MDR R TC1=0 TC2=0
*    Breakdown
RZ 2 3 8.76289
IZG 4 3 1.2
R4 4 3 500
D3 3 4 MD3 TEMP=25
.MODEL MD3 D IS=2.5e-12 N=4.09521e-05 XTI=0 EG=0.1
D2 5 4 MD2 TEMP=25
.MODEL MD2 D IS=2.5e-12 N=0.000478944 XTI=0 EG=0.1
EV1 1 5 6 0 1
IBV 0 6 0.001
RBV 6 0 470000 MDRBV
.MODEL MDRBV R TC1=0
*-- SPICE3 DIODE MODEL DEFAULT PARAMETER
*  VALUES ARE ASSUMED
*IS=1E-14 RS=0 N=1 TT=0 CJO=0
*VJ=1 M=0.5 EG=1.11 XTI=3 FC=0.5
*KF=0 AF=1 BV=inf IBV=1e-3 TNOM=27
.ENDS SRDA05-4-n
.SUBCKT SRDA05-4-p 2 1
* MODEL FORMAT: PSpice
*     anode cathode
*node: 2      1
*    Forward Section
D1 2 1 MD1
.MODEL MD1 D IS=2.06333e-15 N=1 XTI=1 RS=10
+ CJO=2.5e-12 TT=1e-08
*    Leakage Current
R 1 2 MDR 3.6e+10
.MODEL MDR RES TC1=0 TC2=0
*    Breakdown
RZ 2 3 8.76289
IZG 4 3 1.2
R4 4 3 500
D3 3 4 MD3
D2 5 4 MD2
EV1 1 5 6 0 1
IBV 0 6 0.001
RBV 6 0 MDRBV 425000
.MODEL MDRBV RES TC1=0
.ENDS SRDA05-4-p
.SUBCKT SRDA05-4-t 7 1
*     anode cathode
*node: 7      1
*    Forward Section
D1 2 1 MDD1 TEMP=25
.MODEL MDD1 D IS=1.37284e-15 N=1 XTI=1 RS=0.5
+ CJO=3.4e-10 TT=1e-08
*    Leakage Current
R 1 2 5e+07 MDR
*    Breakdown
RZ 2 3 0.458105
D3 4 3 MDD3 TEMP=25
.MODEL MDD3 D IS=2.5e-15 N=0.5
EV1 1 4 6 8 1
IBV 0 6 0.001
RBV 6 0 7300 MDRBV
D4 8 0 MDD3 TEMP=25
L 7 2 1e-15
IT 0 8 0.001
.ENDS SRDA05-4-t
Originally posted in cdnusers.org by umarshah
    Hi Umar,
    Careful, it may not be wise to post proprietary/copyrighted models on a public forum.
    Most of the SPICE syntax I see should run as is.  You will need to adjust the Diode syntax a bit.  Check your Espice syntax manual for help.  You could also convert the Resistors that use a .Model to a one-line "R" statement.  But the rest of the syntax looks fine.
    Once adjusted, paste the text into an N-terminal black box model for use in SigXp.  There's help on that in the manual, or you can simply clone one out of the default library.
    Donald
    Originally posted in cdnusers.org by Donald Telian
