  3. Rat shown on via despite connection
  • Replies 7
  • Views 17338
Bijanbina
Bijanbina over 7 years ago
In Allegro 17.2 HF045 when I add shape or cline to connect a pin to pin still the rats for some via is shown. As in picture below clearly both pin are connected but the rat is shown. How can I fix this? This happen in many part of the board.
If anything more is needed like via padstack or a test board please let me know
  • excellon1
    excellon1 over 7 years ago
    Hi
    Maybe try this. In the picture you have two overlapping shapes that are associated with the net "AV1B_SW" near the bottom left hand side of the chip. Merge these shapes so they don"t overlap. To do that go to shapes > merge shapes on the tool bar. click one of the shapes then click the other. They should merge into one shape.
    Next re-route the cline that is connecting to that AV1B_SW shape plane from the pin at the bottom right hand side of the chip.
    See if the nets go away. The other thing to check is that your vias associated with the A1VB_SW net are truly connected to a plane or trace on the other layers of the board. They may not be !
    Paul.
  • Bijanbina
    Bijanbina over 7 years ago in reply to excellon1
    Thanks Paul for your reply.
    I tried use merge on two shape but the second shape is actually an exposed pin defined in symbol (I cant select it in merge command). I removed the power plane and take a new screenshot. What is clear to me is that the the parts are connected on Top layer (colored as red). Nevertheless allegro show rats. Isn't a single connection point sufficient? Should it have connection from internal alternative layer too?
    Also I removed vias but the rats remained (between two shape and chip A1V8_SW pin)
  • steve
    steve over 7 years ago in reply to Bijanbina
    The issue is that the shape and cline does not connect to the origin of the Pin. You MUST make sure that any clines or shapes cover the origin point of the pin to make connection,
  • Bijanbina
    Bijanbina over 7 years ago in reply to steve
    Thanks steve. problem solved. BTW are you the man behind parsys youtube channel? I watch those and really love them. I couldn't be here without those videos.
  • stumpsr1019
    stumpsr1019 over 7 years ago in reply to Bijanbina
    Believe that might be a gentleman named Gary Hinde, and I agree that they are fantastic.
