  3. Signal names in traces or pins
  • Views 14368
TiBo
TiBo over 7 years ago
Is there anyway to change fond/size/hi-lite the netname in traces or pins in allegro?
TiBo
  • steve
    steve over 7 years ago
    You can't change font or size but try adjusting the global transparency of the objects (Display - Color Visibility, Display tab) and see if that helps, If you have S048 (latest hotfix) there is now an object filter in the same location which may also help,
  • TiBo
    Thank you
